Customs...
07/09/2016 at 02:20 • 0 commentsExpecting a component order to start building the drone, but .... Customs!
Deciding the drone platform and PID code...
07/09/2016 at 02:14 • 0 commentsAfter searching around and seeing several platforms i choose this one to start developing and modifying the drone platform:
https://github.com/alduxvm/DronePilot
mainly because they already have developed a hover software with a PID algorithm and the hardware is based on a raspberry pi/odroid.
mw-hover-controller.py -> Computer pilot commands (using a PID structure) to make a Multiwii multicopter hold a specified x,y,z coordinate.
Do you have any criticism to this choice or a better suggestion? Please comment.
Is it possible?
07/09/2016 at 01:52 • 0 commentsLast January, Northrop Grumman released to the public, a case report in the development of the space starshade...
https://cdn.hackaday.io/files/11906509386304/Warwick_ExoPAG13.pdf
Look how it blocks light from Jupiter:
It works on the ground and has already the potential to separate light sources in globular clusters!
