Connections:
netBoot with a case:
Version 1:
Version 2:
Scheme:
Source code:
#include <SPI.h>
#include <UTFT.h>
#include <Ethernet.h>
#include <ICMPPing.h>
byte mac[] = {0x00, 0xAA, 0xBB, 0xCC, 0xDE, 0x02};
EthernetClient client;
#define MAX_IPs 5
IPAddress pingAddrs[MAX_IPs];
int CNT = 0;
int ERRORS_COUNT = 0;
SOCKET pingSocket = 0;
char buffer [256];
ICMPPing ping(pingSocket, (uint16_t)random(0, 255));
extern uint8_t SmallFont[];
UTFT myGLCD(UNO_26,A2,A1,A3,A4); //USE UNO_26 FOR ST7787/7781 / UNO_24 FOR SPFD4508A
int Y = 0;
void setup()
// Setup the LCD
pinMode(A0,OUTPUT); // for the UNO_SHIELD_1IN1
digitalWrite(A0,HIGH); // the RD pin must be set high
myGLCD.InitLCD();
myGLCD.clrScr();
pinMode(9,OUTPUT);
digitalWrite(9,HIGH);
pinMode(8,OUTPUT);
digitalWrite(8,LOW);
Serial.begin(9600);
Serial.println("Initing...");
Y = 20;
myGLCD.setColor(0, 0, 180);
myGLCD.fillRect(0, 0, 319, 14);
myGLCD.setBackColor(0, 0, 180);
myGLCD.setColor(255, 255, 255);
myGLCD.setFont(SmallFont);
myGLCD.print("netBOOT - Zola Lab", CENTER, 2);
myGLCD.setBackColor(0, 0, 0);
myGLCD.print("Initing...", LEFT, Y);
Y += 20;
delay(2000); // mantem 2 segundos com a ethernet desligada (reseta a ethernet)
digitalWrite(8,HIGH);
delay(2000); // mantem 2 segundos com a ethernet ligada, antes de executar ethernet.begin
pingAddrs[0] = IPAddress(74,125,26,147); // google.com
pingAddrs[1] = IPAddress(8,8,8,8); // dns google
pingAddrs[2] = IPAddress(200,221,2,45); // uol
pingAddrs[3] = IPAddress(23,216,170,96); // microsoft
pingAddrs[4] = IPAddress(31,13,73,1); // facebook
Y += 20;
delay(3000);
while(Ethernet.begin(mac)==0) {Serial.println("Failed to configure Ethernet using DHCP");myGLCD.print("Failed to configure Ethernet using DHCP", LEFT, Y);};
Clear();
printIP();
void loop()
if(ERRORS_COUNT >= 3)
ERRORS_COUNT = 0;
boot();
if(CNT >= MAX_IPs) CNT = 0;
ICMPEchoReply echoReply = ping(pingAddrs[CNT], 4);
if(echoReply.status == SUCCESS)
ERRORS_COUNT = 0;
sprintf(buffer,
"IP: %d.%d.%d.%d TIME: %ldms",
// echoReply.data.seq,
echoReply.addr[0],
echoReply.addr[1],
echoReply.addr[2],
echoReply.addr[3],
// REQ_DATASIZE,
millis() - echoReply.data.time
// echoReply.ttl
else
sprintf(buffer, "Echo request failed; %d", echoReply.status);
ERRORS_COUNT ++;
Serial.println(buffer);
myGLCD.print(buffer, LEFT, Y);
Y += 20;
if(Y >= 240) Clear();
delay(1000);
CNT ++;
void boot()
Clear();
Serial.println("BOOT");
myGLCD.print("BOOT", LEFT, Y);
Y+=20;
digitalWrite(9,LOW); // desliga o modem, por tanto, o relay deve ser usado em NO, ao inves de NC... ou seja, o relay desligado permite que o router fique ligado. Ao acionar o relay, a energia do router eh cortada.
delay(5000); // aguarda 5 segundos com o modem desligado
for(int j=0;j<150;j++) {myGLCD.print(".", j*2, Y);delay(2500);};
// delay(60*1000*5); // aguarda 5 minutos para o modem inicializar e reconectar, evitando que a rotina o desligue novamente.
Y+=20;
Y+=20;
printIP();
void Clear()
Y = 20;
myGLCD.setColor(0, 0, 0);
myGLCD.fillRect(0, 20, 319, 240);
void printIP()
Serial.print("My IP address: ");
myGLCD.print("My IP address: ", LEFT, Y);
String IP = "";
for (byte thisByte = 0; thisByte < 4; thisByte++)
int ip;
ip = Ethernet.localIP()[thisByte];
IP = IP + String(ip) + ".";
IP = IP.substring(0,IP.length()-1);
IP = IP + " ";
Serial.println(IP);
myGLCD.print(IP, RIGHT, Y);
Y+=20;
Eduardo Zola
Claus Buchholz
engineerkid1
M.R. Inc
Yes, it´s an idea... but, I could want to reset two or more devices on the same outlet power strip...
