RTI_Processor_.Net_64.zip
Latest version of RTI_Processor program, to create datafiles from photosets. This is for 64-bit Windows only. Adds the "ptmfitter" program from the University of Southampton, which speeds up PTM datafile creation tremendously, and allows for images up to 100 megapixels in size. Also includes the original "ptmfit" program to use in creating RGB PTM files. A few additional minor tweaks and improvements.
x-zip-compressed -
12.40 MB -
01/18/2019 at 19:24
Download
multiCameraIrControl.zip
Sebastian Setz's Arduino library for IR remote shutter control of several camera types (Canon, Nikon, Sony, etc.). Original link is dead, software is Creative Commons license so it can be ffreely distributed.
x-zip-compressed -
15.61 kB -
01/18/2019 at 19:08
Download
RTI_Processor_.Net_031117.zip
Helper program to speed up processing of RTI photo datasets generated by the RTI-Mage system. This is the new .Net version, replacing the older VB6 version. 32-bit, so should run on all versions of Windows from XP through 10.
x-zip-compressed -
1.92 MB -
03/11/2017 at 21:53
Download
RTI_Processor_source_code.zip
VB .Net source code for RTI Processor .Net utility. Works on Visual Studio 2015 Community Edition and later.
x-zip-compressed -
4.30 MB -
03/01/2017 at 19:09
Download
RTI-Mage Assembly Flowchart.svg
Build/assembly flow chart for the RTI-Mage system, breaking down the build into modules that can be built concurrently by multiple participants.
svg+xml -
15.74 kB -
12/26/2016 at 05:22
Preview
RTI-Mage_PDF_Manual_1.zip
Instructions/logs in PDF format, part 1.
application/x-zip-compressed -
36.72 MB -
12/26/2016 at 05:22
Download
RTI-Mage_PDF_Manual_2.zip
Instructions/logs in PDF format, part 2.
46.58 MB -
12/26/2016 at 05:22
Download
Advanced_stand.pdf
Instructions for the advanced RTI system stand. Good for small domes (
Adobe Portable Document Format -
7.80 MB -
11/27/2016 at 22:13
Preview
RTI-Mage_Main_Control_1.20.zip
Main control program for the RTI-Mage system. Version 1.20, released 10/27/16.
x-zip-compressed -
6.43 kB -
10/28/2016 at 06:03
Download
RTI-MAGE_components_list.xlsx
Excel spreadsheet with build components
sheet -
15.11 kB -
10/10/2016 at 04:26
Download
RTIMage_Controls_Tester.zip
Arduino program to simplify hardware testing and debugging of RTIMage control box.
x-zip-compressed -
3.07 kB -
10/05/2016 at 03:45
Download
RTIMage_Current_Setter.zip
Arduino program to aid in setting of output current for RTIMage control box.
x-zip-compressed -
3.11 kB -
10/05/2016 at 03:45
Download
RTIMage_OLED_Tester.zip
Arduino program for testing and evaluation of 0.96" OLED I2C display.
x-zip-compressed -
1.40 kB -
09/30/2016 at 04:05
Download
RTIMage_Dazzler_Serial_Test.zip
Arduino programs for testing LED wiring in RTI dome.
x-zip-compressed -
2.84 kB -
09/30/2016 at 04:04
Download
RTIMage_System_tester.zip
Arduino program for testing combined MOSFET Driver Shield and CAT4101 board, plus LEDs
1.77 kB -
09/30/2016 at 04:05
Download
