As one can see above, we have a heavy duty tracked replacement for sid the weedy. Metal chain and feet await some kind of foot and the gear box nears completion. Its been a brutal time cutting the boss's off gears, machining shafts and trying to delicately weld the gears with a horrifically over the top welder.
