Why won't it work without a USB cable?
05/26/2014 at 23:52 • 0 commentsWhen I powered the devkit from +5 and disconnected the USB cable, I couldn't get the FAULT LED to go away,
I tried powering the USB interface from +5 also, but that didn't work either.
I started checking logic levels with a volt meter, and found out that RESET* was always low even when I switches the DIP switch that's supposed to control it.
RESET* and ENABLE are transistor-or'd together so that either the USB chip or the DIP switch can control them.
Probing around told me that the transistor was not letting go of RESET* even when the USB interface was powered down.
So we cut the part out and now I can run the board just with STEP and DIRECTION inputs.
Startup.
05/20/2014 at 19:04 • 0 commentsUnboxing shows a PCB and a CDROM.
Plug in the CDROM and I get a "READMEFIRST.TXT" file that says:
1) Click on Setup...
2) Then plug in the USB cable.
USB CABLE???? For a stepper motor driver?
Well, they have some really poor GUI for click-n-test that has NO documentation, will connect to ANY attached FTDI USB interface (Such as the FTDI cable I have running my arduino) and makes a general mess on things.
After a half-day, I got the darn thing stepping from the Arduino, but I'll have to figure out how to get it running without starting up the GUI and clicking boxes pretty soon.
Alan Kilian
