ECG make a function of typical holter. It has an autonomy of 48 hours and record Two ECG signal and Three accelerometer lecture and button event for after display in a Viewer on PC to see the form of ways and after analyze.
ECG built with dsPIC30F6011A + Accelerometer + Usb-TTL + microSD Sniffer + HMI Visor
Setup_Visor.exeInstalador del Visor / Viewer Installerx-msdownload - 2.42 MB - 06/04/2016 at 20:04 |
Codigo.ECG.MPLABX.rarBuilt on Mplabx and XC16 compiler. This is my last issue. see you soonRAR Archive - 1.61 MB - 06/04/2016 at 18:46 |
Hola David! che te quería consultar si me podes dar una mano en la escritura de los datos del ECG en la SD, tengo el problema que no puedo saber, en que formato guardar la información de cada canal para luego guardarlo en formato BIN.
