DCNC28Sep18.zip
CAD program
x-zip-compressed -
1.82 MB -
09/23/2018 at 03:48
Download
DCNCTerminal 22Sep18.zip
Terminal to communicate with machine
x-zip-compressed -
109.58 kB -
09/23/2018 at 03:47
Download
Firmware 22Sep18.ino
Machine software
ino -
29.42 kB -
09/23/2018 at 03:47
Download
PCB Mill 28Aug18skb.skp
The sketchup of all the parts
SSEYO Koan Play File -
7.86 MB -
08/29/2018 at 02:50
Download
DCNC.zip
OLD The limited CAD program I made to easily design quick little things. The circuit board designs for the controller was made with this. Updated it to produce G Code and send it to the DCNCTerminal program.
x-zip-compressed -
1.83 MB -
08/29/2018 at 02:47
Download
DCNCTerminal 28Aug18.zip
OLD Windows program, syntax colored text editor for teh gcode subset the firmware interprets, and also sends the "gcode" to teh controller. Updated to include a parity byte for dem corupt messages u noe.
x-zip-compressed -
109.25 kB -
08/29/2018 at 02:46
Download
Firmware 28Aug18.ino
OLD The limited subset gcode interpreter firmware for the arduino (well the cheap cheap chinese copy) that controls the machine.
ino -
21.80 kB -
08/29/2018 at 02:43
Download
Firmware.ino
OLDDDD The arduino sketch that the DCNCTerminal program talks to and cotnrols the steppers and shit to make the machine do what it do. naw im sayinnnnn. get rekt.
ino -
18.63 kB -
11/16/2016 at 01:31
Download
DCNCTerminal.zip
OLDDDDDWindows program, syntax colored text editor for teh gcode subset the firmware interprets, and also sends the "gcode" to teh controller.
x-zip-compressed -
74.30 kB -
11/16/2016 at 01:30
Download
PCB Mill 11Oct16.skp
OLDDDD A few small changes, added some reinforcements to make use of scrap I have laying around, and made it match the physical product.
6.30 MB -
10/12/2016 at 05:22
Download
DCNC 23Oct16.zip
Oldddd. Small change to the CAD program, included a 5 second delay when opening a comm port to alleviate issues I was having.
x-zip-compressed -
145.93 kB -
10/23/2016 at 21:50
Download
DCNCController v4.ino
Oldddd. newerer arduino software. Due to the board change, pin mapping changed, and added support for controlling a fan, or whatever other low amp (
ino -
13.13 kB -
07/29/2016 at 06:07
Download
PCB Mill 22Sep16.skp
Oldddd. Old. Sketchup design of it. Redesigned most the parts making them beefier and adding a third rod for the y axis to make it wobble less in that axis. I'm sure there was a better way, but this was easy.
Also included a different piece for clamping objects to the work area.
5.78 MB -
09/23/2016 at 03:25
Download
PCB Mill 30Jul16.skp
Oldddd. Old.Latest version, includes the new housing for the new controller which incorporates a cooling fan.
5.39 MB -
07/31/2016 at 02:35
Download
PCB Mill 17Jul16.skp
Oldddd. Old. PCB Mill 4, added the keypad model, and updated the controller enclosure to include a slot for a female power supply adapter to sit in.
5.43 MB -
07/17/2016 at 22:04
Download
DCNC 30Jul16.zip
Oldddd. Old. The CAD program, and also the program that sends the commands to the controller for milling. I'm going to abandon this, and create a new one from scratch as I find you do better work that way.
included is the Pelles C project file and all associated source code. The source is very much a mess, so dont judge me judy.
x-zip-compressed -
144.69 kB -
07/31/2016 at 02:33
Download
DCNCController v 3.ino
Oldddd. Old. newer arduino software, added keypad disable/enable commands, and also a provision to accept keypad commands to move steppers.
ino -
12.16 kB -
07/17/2016 at 21:56
Download
DCNCController.ino
Oldddd. Old. arduino software, newer version, added a command for enabling and disabling the steppers.
10.47 kB -
07/11/2016 at 06:02
Download
PCB Mill 3.skp
Oldddd. Old. Newer version with better x carriage with slots and shizzle to hold boards down. dawg.
5.26 MB -
07/09/2016 at 05:02
Download
PCB Mill 2.skp
Oldddd. Old. New beefier version, there was too much play when I started using a drill, with the addition of room for more bearings, its much better.
5.03 MB -
06/12/2016 at 21:17
Download
PCB Mill.skp
Oldddd. Old. Sketchup file of my design
5.03 MB -
06/06/2016 at 21:41
Download
