CAD Software
06/29/2016 at 06:13 • 0 commentsThought Diarrhea :
So, I'm taking my sweet time building the CAD software that will generate the data that my, yet to be programmed, controller program will read and talk to the microcontroller to make the machine do what it needs. But, its coming along and almost done.
Inside the program, you get to pick between 4 different objects, a line, a rectangle, a circle, and a "drill point".
The line simply lets you designate 2 points that the dremel will mill out
The rectangle does the same, except it will route out a rectangle from those 2 points.
The circle, you designate an XY and radius, and just like everything else, it will do what you think.
The "drill point" lets you designate an XY.
My idea for the actual milling process will be, you feed in the data file from the CAD program, and then it will ask you to insert the specific end mill or bit for the current step. It will iterate through all the objects with the same end mill and then ask you again to install the next end mill for the next step. And the once all those steps are done, the board will be done being etched.
You are currently allowed to designate up to 10 'tools'. A 'tool' is simply a set of variables detailing the bit width, the depth is plunges into the board, and its end mill ID. The end mill ID is just a number saying what bit it is associated with. You can have the same end mill ID for all the 'tools', as each tool has a depth and width with it. So with that, I can have an end mill with a V profile provide for the different widths that need to be milled out.
When you create an object, or anytime after its creation, you associate that object with a 'tool'. And with that association, the controller will know to process all the objects with associated tools that match the current end mill at one time.
The picture above is a design that utilizes one rectangle, a bunch of lines, and a whole buncha drill points.
The listbox on the right side of the screen is where you can set the selected object's tool and modify the tools details. The lines and rectangles are associated with Tool #2, which is associated to the end mill with the ID of 2. The controller would ask you to install end mill 2, and then it would mill out those lines/rectangle.
Next, it would ask you to install end mill #1 (a drill bit) and then it would go through and drill each drill point.
The software is working, I just need to pretty up the GUI, create some settings dialogs, and create a routine that will export a data file for the yet to be created controller program to interpret.
But whatevs. #yolo2myboiz
Still working on software, but took a break and etched something
06/25/2016 at 02:50 • 0 commentsWell, im still working on the CAD software, but id say its about 60% complete. Didnt really plan all what i wanted going into it, but its coming along. Added some picks of some blank boards be etche
Testing with aluminum
06/17/2016 at 01:15 • 0 commentswell, the drill i was using sucked, the spindle would move around very easy when trying to mill something, so i installed my dremel i have and my aluminum test etching results improved dramaticallly. Still working on the software -
work work work work work
06/12/2016 at 21:32 • 0 commentsSo I moved from a pen to installing a drill with a lil' routing bit. There was to much play in the x/y axis due to my lack of the linear bearings, or quality of them, I dont know. Anyways, I made it so theres 2 bearings in all those spots now instead of one, and its at least 300% better.
It's pretty loud routing on wood in my apartment, so I'm going to have to figure out a quieter medium to test with so I dont get noise complaints (maybe some kind of wax?)
Besides the hardware, I'm working on a CAD program where I can make designs that will be sent to the controller software that I'm also working on.
The goings slow, but that is due to my accessibility to more fun things that distract me. I'll post another video when I get the software more complete and start compiling the cost of the project (minus the 3d printer). I dont know. #qwikshowtout2myboikeown
Just getting this dude put on here, so not much details yet.
06/05/2016 at 09:21 • 2 commentsWell, I've been working on this a while. Took the plunge and bought a 3d printer and this is my first real project with it so I'm still learning.
I'm on about my 5th redesign and I like where I am right now and am working mainly of the software for it and making a simple CAD program so you can etch some shit.
Heres what I got so far.
