This project uses a particle photon and a shinyei PPD 42 air sensor to publish air quality data to dweet.io as well as use an RGB LED to indicate air quality.
This project was designed to help high school students study and monitor their air quality.
Calibration Data.xlsxData collected with a Dusttrak II and my air sensor.sheet - 71.96 kB - 06/06/2016 at 16:43 |
I am looking into using the LED on the Photon to indicate air quality. You can override the RGB light on the board to light whatever color you want. Might give it a go. This would make the external LED not needed.
https://www.epa.gov/hesc/real-time-geospatial-data-viewer-retigo
I was just informed about the EPA website that can map individual project air data. It is called real time but it looks like you have to manually upload your data spreadsheet to have it graph it. I will keep looking into it.
I just got the code working to feed the data to thingspeak.com. I am hoping that might provide a better solution for mapping data.
I am currently looking for a database to host and display published data.
Further information can be found at https://airquality406.wordpress.com/
