LED removal
06/15/2016 at 02:34 • 0 commentsI am looking into using the LED on the Photon to indicate air quality. You can override the RGB light on the board to light whatever color you want. Might give it a go. This would make the external LED not needed.
RETIGO
06/09/2016 at 17:08 • 0 commentshttps://www.epa.gov/hesc/real-time-geospatial-data-viewer-retigo
I was just informed about the EPA website that can map individual project air data. It is called real time but it looks like you have to manually upload your data spreadsheet to have it graph it. I will keep looking into it.
thingspeak
06/09/2016 at 17:03 • 0 commentsI just got the code working to feed the data to thingspeak.com. I am hoping that might provide a better solution for mapping data.
Database?
06/06/2016 at 17:37 • 1 commentI am currently looking for a database to host and display published data.
Brock Hammill
