Lithium iron phosphate (LiFePO4) battery test
07/09/2016 at 14:27 • 0 commentsI removed LDO from my NodeUSB (ESP8266) board, and use LiFePO4 battery to power it directly.
700 mAh able to run about 6 hours (345 minutes):
2016-07-08 13:04:30.324560
2016-07-08 18:50:05.973346
Then, I charged LiFePO4 battery (3.3V LDO directly) and ran another test:
2016-07-08 23:40:50
2016-07-09 01:15:34
That is 95 minutes, so about 27% of capacity, 190 mAh.
Second test is much batter (I charged longer this time, for 3 hours):
2016-07-09 13:25:18 2016-07-09 16:07:58 162 minutes That is about 47% of the capacity.
If use 3.5V LDO to charge LiFePO4 battery, it can reach 95% of capacity. I will test it next week.
Lithium iron phosphate (LiFePO 4) battery
07/08/2016 at 15:06 • 0 commentsToday I started testing LiFePO4 battery. I had the idea of using LiFePO4 battery for few months. Now I just received the shipment early this week.
Few benefits use LiFePO4 battery:
- Can use LiFePO4 battery directly power MCU, without LDO or buck converter. LiFePO4 battery discharge at 3.2V. This is huge for ultra-low power applications that average 3-15 uA. Even the really good LDO still consume 2-5 uA when MCU is sleep.
- Better high temperature performance.
- Long life, 2,000 charge/discharge cycles
- Large overcharge tolerance and safer performance
- Simplified battery management system and battery charger
First design
07/07/2016 at 14:52 • 0 commentsHere is the schematic of BeWi based on Atmega168 and NRF24l01+:
- Atmega168 read sensor data
- Atmega168 use SPI to talk to NRF24l01+ and send 2.4G BLE beacon packets
- Atmega168 control AO6604 to enable/disable battery charging.
- Atmega168 read battery voltage and decide when to charge, keep battery voltage low can greatly extend battery life
- HT7333 provide power to Atmega168 and NRF24l01+
- C2 is 0.22F super capacitor, depends on the setup, it can power BeWi alone with small solar module
Evaluate different chips/modules for WiFi, BLE beacons
07/06/2016 at 19:14 • 0 commentsAfter testing different chips/modules for WiFi, BLE beacons.
I am leaning toward to use NRF24l01+ send and listen BLE beacon frames.
The reasons:
- TI does not provide API to use CC2540/CC2541 in sniffer mode
- To write software on CC2540/CC2541, you need IAR, which cost $4,000 USD!
- ESP8266 chip use too much power, it is take too long to boot and transmit the packet, the best I can do is 200ms.
Use another MCU (Arduino) with NRF24l01+ , anything can develop the firmware fairly easy. Cost will be low.
