DIY CNC MACHINE
Wood structure, arduino controled, cheap and easy to build.
Structure from scratch pieces of wood or similar. Chinesse linear bearing and rods. Arduino+Ramps1.4+A4988 drivers+Nema 17 stepper motors.
Marlin for control. Very high precission. Power depend on spindle.
The machine is a simple structure repeat 3 times (with differents size), one for each axis: A table mount in a linear movement.
A fix gantry it's the best option in this case for the high weight of the materials.
The basic structure have: two rods and support, four linear bearing with a table attached, and a lead screw and bearing suports. The motor are a Nema 17 stepper motor.
The Y axis are mounted in the base,
The X axis are mounted in the fix gantry. And the Z axis it's mounted in the movil table of X axis.
Arduino Mega 2560 board for control, with ramps 1.4 for driving motors and Marlin (with little modifications), as firmware.
Simple, cheap, affective.
supp_nut.stl
Printed piece for support bronze nut of the lead screw
sla - 62.39 kB - 06/16/2016 at 14:35
Download
supp_linear.stl
Suplement for Linear bearing
sla - 26.64 kB - 06/16/2016 at 14:35
Download
supp_lead.stl
Suplement for bearing support of the lead screw.
sla - 13.56 kB - 06/16/2016 at 14:35
Download
  • 4 × rods 12mm x 400mm
  • 2 × rods 12mm x 300
  • 12 × Linear Rail Shaft Support 12mm
  • 3 × T8 300mm Lead Screw 8mm
  • 6 × Mounted ball bearing Bore diameter: 8 mm
View all 22 components
  • Spindle support
    jvsalatino06/16/2016 at 15:07 0 comments
    The spindle support depend on of the type of spindle you use. If the spindle it's bigger maybe you need to put a bigger motor in the Z axis
  • Printed pieces
    jvsalatino06/16/2016 at 15:03 0 comments
    In the FILES section there are tree *.stl files.
    SUPP_NUT.stl , it's the support for the nuts of the lead screw. You need print 3 of this.
    SUP_LINEAR.stl, it's a suplement for each linear bearing. This piece it's neccesary for the table can move over the stepper motor. You need print 12 of this.
    SUPP_LEAD.stl, it's de suplement for each bearing support of the lead screw, and it's neccesary to put a the same level the lead screw and the motor shaft. Yo need print 6 of this.
    Sorry for my english.
  • Comments
    jvsalatino06/15/2016 at 22:40 0 comments
    All size of the wood pieces are in mm. The material MDF, WOOD from scratch or any similar.
View all 3 project logs
