Spindle support
06/16/2016 at 15:07 • 0 commentsThe spindle support depend on of the type of spindle you use. If the spindle it's bigger maybe you need to put a bigger motor in the Z axis
Printed pieces
06/16/2016 at 15:03 • 0 commentsIn the FILES section there are tree *.stl files.
SUPP_NUT.stl , it's the support for the nuts of the lead screw. You need print 3 of this.
SUP_LINEAR.stl, it's a suplement for each linear bearing. This piece it's neccesary for the table can move over the stepper motor. You need print 12 of this.
SUPP_LEAD.stl, it's de suplement for each bearing support of the lead screw, and it's neccesary to put a the same level the lead screw and the motor shaft. Yo need print 6 of this.
Sorry for my english.
Comments
06/15/2016 at 22:40 • 0 commentsAll size of the wood pieces are in mm. The material MDF, WOOD from scratch or any similar.
jvsalatino
