Project Goals
- A robot that can walk in a straight line and not fall down.
- make accurate turns.
- Anyone can program it, from kids to Arduino users to pro C developers.
- Uses a 32bit processor, the ATSAMD21G18A.
- Entire robot can be 3D printed on a 100mm^3 bed.
- Powered by a single cell lithium ion battery that is charged over micro USB.
- Controlled wirelessly via WiFi on the ESP8266, hopefully peer to peer compatible so no wireless network is required.
- Store multiple programs on board so you don't need to reflash every time you want the robot to do something different.
- Self programmable; program on the robots face.
- Uses an accelerometer to make walking gaits smoother and tells the robot if he has been pushed over.
- Uses a 2.8in TFT display for running programs without a computer, configuration and more
- 7 servos for legs, arms, and head.
While I am waiting for the new boards, I hope to get the 3D models in working order running off a ATMEGA328 so I am not wasting time waiting for parts.
Audrey Robinel
Wissam Tedros
Javier Isabel
Alex Martin
I have made some libraries for the SAMD21, see my website, that may help you.
SAMD21 Timer library for the SAM15x15 and Arduino Zero
http://www.avdweb.nl/arduino/libraries/samd21-timer.html
Fast PWM-DAC library for the SAM15x15 and Arduino Zero
http://www.avdweb.nl/arduino/hardware-interfacing/samd21-pwm-dac.html
Fast analogRead / 10-bit ADC for the Arduino Uno and Zero
http://www.avdweb.nl/arduino/libraries/fast-10-bit-adc.html
