The modules will be interconnected as shown here:
Thanks to the Weidmuller ZB35 bus bar clamp, module interconnection will be made easy. This clamp is perfectly suited to the 10x3 mm copper bars I use as collectors.
To remove a module, a 10 mm wrench will be sufficient.
Weidmuller ZB35
The clamps will be directly soldered to the BMS pcb (in blue in the drawing).
