My Spot Welder is finished and I made the first tests on a module assembly populated with 3 cells :
It works fine but the welding time must not be too long, otherwise the can of the battery may get punctured, with the electrolyte leaking out. This means the death of the cell.
A close up of the copper welding electrodes:
