This picture shows the hardware necessary to build the modules:
- The 5 * 14 battery holder - 2 are necessary per module
- The 10 x 3 mm tinned copper bus bars - 31 cm long - 4 are necessary per module
- The 7 mm * 0.1 mm nickel strip - 1,5 m / module
- The 0.5 mm tinned copper wire - for the fuses
- The battery cells are not shown - 70 cells / module
