The 1 Kg roll of Nickel strip I have ordered in China has arrived.
The strip is carefully wrapped and protected against moisture by silica gel.
The weight is OK too:
A project log for A 110 kWh Powerbucket
The lead-acid batteries of my off-grid solar system are dead. I will replace them by a 18650 batteries stack housed in a big wooden box.
