A project log for DAV5 V2.1 Spectrometer
The ZEN of simplicity Making the Complex...Seem Simple
01/07/2018 4:39:PM
What's that little dip in the peak near 546nm? Are there two mercury lines there?
Hey Ted, yes it is, but its not one of the calibration points, the peak though is 542nm, I'll put up another RSpec plot with reference lines for Mercury that will show exactly where the element peaks are at.
I just posted an updated plot showing the HG (mercury lines)
Thanks! I knew there was a double line in the yellow, but never noticed two in the green before.
That's really good. Can you verify/estimate that this spectrum is close to a 6500K color temperature?
Yeah I can Ted, I'm still trying to figure that part out in this program, getting the hang of it :)
That is so cool and it's art as well :-)
Hello good Dr. :)It does look pretty doesn't it?
Yes, delete it Cancel
Hello good Dr. :)
