How I did it.
1 Raspberry Pi
1 Monitor
(in my case a old 21ยดยด TFT 4:3 with DVI Input) which made it easier to connect it to the Pi
1 Old Wardrobe (or a lot of ply wood)
I removed the silver coverage from the wardobe cutted out the arcade case and glued the silver coverage on again.
1 PC Speakers
1 ATMEGA 32U2 Board (e.g. NooGroove: see ebay)
1 Arcade Joystick from ebay
1 xArcade Trackball
A few Arcade Buttons
1 green LED Stripe (for illumination)
I used two existing Projects:
First Kade loader
http://kadevice.com/loader-software/
with this one you can progamm your ATMEGA32U2 to emulate a Keyboard when a Button was hit.
Second http://pimame.org/
This is a great Project from Shea Silverman
It's a multi arcade machine emulator (and much more)
mike
Mx. Jack Nelson
Andrew Garber
Jeremy Cook
Abraham Martinez Gracia
Hi interesting project! So can you confirm that Kade Loader works with NooGroove? how do you configure firmware with trackball.. using the switch function? ... Thanks bye
