Memory successes and problems.
06/26/2014 at 18:05 • 0 commentsThe emulator now lets code access the SD card using I/O instructions. One of these instructions tells the Arduino to load a binary file into the emulated memory. This is nice, however the memory array is stored in RAM, so it is very limited in size. I will likely switch to using flash instead.
It works!
05/26/2014 at 19:53 • 0 commentsI was able to blink the LED on pin 13 using my emulator and Z80 compatible op-codes.
Ryan Gass
