This is a switch I am designing to serve as a low amperage power disconnect switch.
The premise is that you tighten the center screw and the screw bridges to two copper pads causing current to move from one side to the other.
It should open and close positively without vibrating loose.
nerd.king
Jan Petrik
Kyle Isom
