Update #5
10/14/2016 at 18:43 • 0 commentsThe switch is finally done. the larger 4-40 screw works much better. It is available now at my website and the link is in the description.
Update #4
09/28/2016 at 18:50 • 0 commentsI received the new boards they are much better. I will be adding photos and video soon. After a bit of testing if all goes well I will be offering these for sale.
Update #3
09/01/2016 at 17:53 • 0 commentsThe board works quite well but I am not 100% happy with it yet. I have decided to increase the amount of contact area of the screw head by increasing the size of the switch screw to 4-40 from 2-56. I just ordered a set of boards and they should be here in a week or two.
Update #2
07/18/2016 at 18:23 • 0 commentsI finally got around to testing out my switch. It works quite well on my test platform for my dual motor driver speed controller I am developing. So far I have only drawn ~1 amp through it but it should be capable of much more. It is definitely suitable for most antweight (1lb) and under robots and I expect further testing to reveal it will work for beetleweights (3lb) as well.
I need to come up with a accurate and repeatable way to test these. I am thinking about attaching them to a variable load like a brushless motor and a watt meter. Then I can measure how much current they can pull as well as how hot they get (my watt meter has a temp sensor built in)
Update #1
06/23/2016 at 18:25 • 0 commentsI ordered the PCB, and parts from Mcmaster Carr
should have everything in about two weeks to test .
