The board have arrived
07/10/2014 at 20:50 • 0 commentsThe boards that I ordered from Dirty PCB arrived yesterday. I ordered the parts I'm missing from Digikey today, so I should be able to complete the project this weekend.
Board Ordered
06/11/2014 at 23:01 • 0 commentsI ordered the boards for the clock plus some additional projects that fit into 5 x 5 today from dirty pcb.
The software is pretty much completely working as well.
The frame is also cut and the first coat of paint is on.
Stay tuned for some photos.
Board Designed
05/30/2014 at 15:50 • 0 commentsI've decided that this is the project where I dive head first into surface mount. To that end I've decided to see just how small I can make the board. At the moment it's .65" x 1.55". The 328 is TQFP32, the RTC is SO8, and the resistors and caps are all 805. To save space for the ISP headers I'm going to try this board edge technique. (As I write this I wonder why I still have a through-hole crystal on the board?)
I'm also going to try panelizing for the first time and get another design printed at the same time to make the most of the 5x5 space I have to work with (a TQFP32 AT90USB162 breakout).
As for the software, it's mostly working on my breadboard. I've got it driving the WS2811 strip, reading my Apple remote, and working with the RTC over i2c and using the 1Hz clock output -- all using the internal 8MHz oscillator. The code for driving the ws2811 at 8MHz was found here.
LED strip arrived
05/26/2014 at 18:01 • 0 commentsThe LED strip I ordered off of ebay arrived today so time to start playing with that tonight.
Warren Janssens
