Stark 1.0
05/21/2017 at 15:16 • 1 commentI finally had the motivation for a photoshoot.
Video:
Next changes/todo/friend requests:
- Obligatory laser
- Adafruit NeoPixel
- Moar coils
- 7 segments ammo counter
- Portability (2200mAh 11.1V lipo maybe)
- gun reshaping and costume -
Stark 2.0
03/31/2017 at 18:40 • 0 commentsHello,
I finally took time to take pictures of the new verion and also because i got an amazing artwork by the crew of HackerStrip (the webcomic series) thx!![]()
I asked them to draw me a character with a coilgun, it has been an idea who throttle in my head since a bit of time now.
Id like to do my own cosplay and i've already some ideas, coil gun with portable power supply backpack something like the ghostbuster proton gun, a trench coat similar to Hei in Darker Than Black, i've not yet defined a name or even the final clothing/style and coil gun design.
Anyway the gun would be probably not a functional unit to avoid fatigue of carrying coil gun weight all day, and danger problem in congress.
I think about cosplaying a lot these days and i'm repicking design ideas a bit from everyone on HaD coil gun projects.
revisited but haven't changed much.
Most notable feature is the remote control for charging/shooting
ZVS is back again in a single board like the first generation of Stark
The shooting is done tought a solenoid who push the projectile
3D printed ammo magazine:
Flyway tube
Note that metal tube do an induced current in the magnetic field and produce Foucault current and reverse magnetic field who inevitably reduce efficiency.
Coils isn't directly on the metal pipe to avoid sparks at high voltage, this one is more about style rather than kinetic energy.Ferromagnetic projectile (no steel ball like in 1.55)
Detail on the coil and top view with photoelectric module.
Video:
Later if i have time i will take pictures of the Stark first gen.
Stark at OBC Auxerre
10/01/2016 at 07:14 • 0 commentsAnd so we bring the coil gun to the second edition of OBC Auxerre (Open Bidouille Camp) to show it to people and explain the theory behind.
That was a huge success with more of 750 visitors to the event.
Chronograph test
09/15/2016 at 18:52 • 0 commentsIt was time to measure the velocity of projectiles.
Burn Babylon Burn!
07/16/2016 at 21:25 • 0 commentsWaiting new components from our Chinese friends due to a fail (comutator have burn inside causing him to be stuck in closed mode and damaged really bad the board.
On second transistor plastic near the screw also melted away due to big current.
Waiting for new components and working on a board fix, probably stuck for a month time to produce also a new batch of board...
Edit: DHL was faster than excepted, received everything and the new switch do an awesome *click* sound.![]()
Xylitol
