You will need 2 electronic boards to build the Spot Welder:
1 - an XSBO processor board - described here #a Break Out Board for an eXtremely Small Proc.
2- a TRIT board - all the files are provided in this project.
NOTE: I can provide the XSBO board populated, tested and programmed with the spot Welder application.
Hi Michel,
very nice and clean job!
Could you provide some Infos to the pcb?
I'm very interested in rebuilding this project!
