In this newer version i 3D printed the parts with the DLP 3D printer I designed. The steel plates were lasercut, and my idea was to use one plate for the whole character instead of one for each pin; unfortunately, i later found out that the steel they used was problably stainless steel, and almost not ferromagnetic (also quite expensive to make).
Madaeon
