Testing the actual measures and new parts
05/28/2014 at 09:44 • 0 commentsI’m currently testing the current measures as standard mounting for M3 screws (each person can personalize their measures).
Actual hole spacing is 12 mm but I think if I use 14 mm the pieces will stay stronger and easier assembly with M3 screws.
![First test pieces]()
Regards and happy hacking!
JRodrigo
