Kit available:
Design goals:
- Make a complete, nothing missing, DIY kit (the kit is now available, see http://muffsy.com)
- Dual mono topology
- Price target: USD 79
- Easy and understandable build documentation
- SNR above 70 dB (referenced to 0.5 mV input)
- Variable input impedance
- DC servo to eliminate input/output capacitors
- Gain of 24.6 dB - 0.3 mV input gives 5 mV output (0.5 mV in: 8.5 mV out), at 1 kHz
- No power cables across the signal paths
- Dual layer PCB, immersion gold plated
- PCB width: 84.0 mm / 3.3 in
- Make the complete head amp with PSU fit in a B0905 enclosure
- Improved back panel
Project Status:
- Schematic, routing and PCB rendering for Muffsy MH-1 available here
- Schematic: Done
- PCB layout: Done
- Component selection: Done
- Component sourcing: Done
- PCB manufacturing: Final version received
- Testing/measurements: Click here for details, and see specifications below
- Documentation: Done (these project pages), and here: http://www.muffsy.com/build-the-muffsy-mc-head-amp-mh-1.html
- Kit ready: Done
Specifications:
- Topology: Dual mono
- Gain: 24.6 dB
- Input impedance: 47 - 100, or 50 - 300 ohms in 4 steps, or choose your own values
- THD: < 0.1 % *)
- THD+N: < 0.1 % *) (measured: 0.6 %)
- SNR: 71.8 dB
- Frequency Response: +0 / -0.1 dB (20-20.000 Hz)
- IMD (ITU-R): 0.001 %
- Dynamic range (referenced to 0 dBV output): > 110 dB
- Power requirements: +/- 15V at < 40 mA
- PCB Size: 84.0 x 59.4 mm / 3.3 x 2.3 in
*) The inherent noise and harmonics in my signal generator is too high too accurately measure the THD and THD+N at these low levels. The numbers are too high, both should be well below 0.1% as the measurement without the noise shows that. I've added my measurements for reference anyway.
All ground points are connected on both the top and the bottom ground, so it's more or less like connecting ground planes with vias.
The final version of the Muffsy MC Head Amp is now tested, and there's not even a hint of grounding problems: https://hackaday.io/project/12483/log/45728-the-final-version-of-the-mc-head-amp-sings
