• Captains log stardate 20180412, first entry
    James Wynhoff • 04/12/2018 at 19:41 • 0 comments
    The boilerplate is just about ready, Ill be uploading code here shortly if anyone wants to play with it.
    So far it.....
    restores ssid / password from eeprom on boot
    Connects to a saved AP
    if it fails it goes into softAP mode for 5 minutes, before retrying
    softAP uses a captive portal to let you configure the wifi
    uses the mac of the ESP to generate its JAW.HA ID
    supports firmware update from the arduino IDE (and soon an independent firmware updater)
    advertises its presence via mDNS
    advertises its presence via JAW.HA Admin port
    Next is the application code framework!
