You must have made some kind of toy car as a beginner! This instructable will take you through detailed assembly of a modular mobile robot which can be used for:
Line following robot
Obstacle avoiding robot
Wall following robot, using evive.
The most important fact about this design is that its modular. You can iterate over different configuration of line following sensor, servo and ultrasonic sensor giving you robot for different applications without any hassle.
Details
Components
1×
evive
arduino powered embedded platform For more info - http://evive.cc/
1×
Ultrasonic sensor
ultrasonic sensor for arduino
1×
servo motor
a servo motor for arduino
1×
5 or 7 array IR sensor
1×
Base Plate & Upper Plate
Like the one in the image of robot
First, we will mount motor clamps which is used to fix motors to the
base plate. The plate have the mounts for two clamps. Mount the clamp
with for nut bolts tightly.
3
Step 3
Mounting motors and wheels to base plate
After you have mounted the clamps, then we
will mount motors. Unscrew the nut from the motor, then insert the motor
in the clamp and screw back the nut to fix the motor in the clamp.
Then do the same thing for the second motor motor.
After this, you can mount the two wheels on the motor's shaft. Make
sure that the wheels are compatible with the motor so that it can be
attached and screwed easily and firmly.
