CAN Bus - The Basics
09/28/2018 at 08:34 • 0 commentsAfter a period of laying the ground work on some simpler protocols in my YouTube channel, I've finally got to the point where I'm dealing with the CAN Bus Protocol. Hopefully this means that new episodes will be appearing slightly more frequently in future. For now it's a start:
I probably over stress the fact that CAN Bus has no address in its Layer 2 Frame, but it's why the protocol is so useful. Given that the OSI 7 Layer model stipulates that layer 2 frames should contain a source and destination address perhaps the CAN Bus protocol might be considered as being at layer 1.5 of the 7 layer OSI Model? Perhaps but there's no way I'm putting '1.5' into variable and function names ;)
Another libesoup fundamentals video
04/24/2018 at 19:14 • 0 commentsI'm getting to the project vehicle, Input and Output boards are on order, so I'll try and get some sort of update on that aspect of the project soon. Mean time another fundamentals video on using some of the API's in libesoup. This time simple UART Transmission. It's basic but I'm trying to build up from the basics to CAN Bus and USB protocols.
