Here is a image print out prior to transfer. This is showing the 0603 resistor pads.
JPEG Image - 199.84 kB - 04/15/2018 at 13:58
Preview
A board prior to etching. This is where I noticed the problem as regards to the lack of mirroring. I use toner transfer method via the cold process(i.e. mix acetone/alcohol, coat the board, apply paper, clamp, wait, remove paper under running water)
JPEG Image - 670.87 kB - 04/10/2018 at 11:24
Preview
One of my early attempts. Looked fine until I noticed that I had failed to mirror the image prior to printing... Arrgghhh
JPEG Image - 614.58 kB - 04/10/2018 at 11:21
Preview
board_copper_1.14_A.pdf
An early attempt to print out a PCB. Then I noticed that Eagle had not included some pads, no vias or no contacts. That took me a little while to hunt and cure.
Adobe Portable Document Format - 2.29 kB - 04/10/2018 at 11:13
Preview
sch01_out01_18MAR18.pdf
Early schematic of the power system.
Adobe Portable Document Format - 88.36 kB - 04/10/2018 at 08:49
Preview
