Comments now displaying using brute force!
07/15/2016 at 03:07 • 5 commentsSome how, some way I figured out how to display the comments. It's a total butcher job of the code, a better programmer probably would have some elegant way to do this with recursion or something, instead I just used three for loops. But hey, it's working! Good example of comments displaying (even third tier level) is shown on this page:
http://www.stickvise.com/blog/2
Here is the new print_comments function I made to brute force the display of comments in the correct nested manner. I
// print_comments function function print_comments($comments) { // loop through comments array echo '<ul>'; foreach($comments as $comment_object1) { // find and print first tier comments if($comment_object1['reply_to'] == 0) { echo ' <p><a href="'.$comment_object1['user']['url'].'" target="_blank">'.$comment_object1['user']['screen_name'].'</a><br /> '.$comment_object1['comment'].' </p>'; // loop through comments array again to find second tier comments echo '<ul>'; foreach($comments as $comment_object2) { // find and print second tier comments replying to the above tier comment if($comment_object2['reply_to'] == $comment_object1['id']) { echo ' <p><a href="'.$comment_object2['user']['url'].'" target="_blank">'.$comment_object2['user']['screen_name'].'</a><br /> '.$comment_object2['comment'].' </p>'; // loop through comments array third time to find third tier comments echo '<ul>'; foreach($comments as $comment_object3) { // find and print third tier comments replying to the second tier comment if($comment_object3['reply_to'] == $comment_object2['id']) { echo ' <p><a href="'.$comment_object3['user']['url'].'" target="_blank">'.$comment_object3['user']['screen_name'].'</a><br /> '.$comment_object3['comment'].' </p>'; } } echo '</ul>'; // end third tier comments } } echo '</ul>'; // end second tier comments } } echo '</ul>'; // end first tier comments } // end print_comments()
Alex Rich
