Parts on Order
A project log for Monoprice Select Mini Electro-Mechanical Upgrades
Endeavoring to build upon the existing fanbase work of this $200-ish printer.
michael-obrienMichael O'Brien 07/19/2016 at 12:510 Comments
Placed an order for some goodies:
Side note, found 2 of the 'stock' hotends on Amazon while browsing around:
I realize that I'll be pushing the provided power brick to its limit, however, I'll only be testing one upgrade at a time. Initially, I will be hooking up my scope and current probe(s) to monitor current draw in order to correctly tune the *stock* heater and heated bed. Based on the current observations from the printing I've done, it appears that I'll have to build in some rapid (2-5 Hz), low amplitude oscillations in order to compensate for the thermistor noise that produces inherent instability.
