Limit Switches and Current Limits
A project log for Monoprice Select Mini Electro-Mechanical Upgrades
Endeavoring to build upon the existing fanbase work of this $200-ish printer.
michael-obrienMichael O'Brien 07/18/2016 at 19:390 Comments
Having experienced a jam already along with noting that the limit switches only apply to 0, 0, 0, I'm now interested in looking at running specific tests to determine max current draw of the steppers and see what can be adjusted by the stepper drivers or in/with GCODE. Calibrating the extruder, monitoring current consumption to fine tune PID properly, et al is on my list of to-dos.
