I**A CNC - PCB Test
08/12/2016 at 13:32 • 0 commentsI could not resist to make some test if my CNC can also do pcb's.
No problem on this :) Here i used the "Probe"-Feature of Grbl to get the exact position of the pcb. But then i milled to deep ;)
New X-Train ready...
07/28/2016 at 19:28 • 0 commentsHere a small explication video how it works.
The new x-axis train with bearings in almost ready :)
07/28/2016 at 15:43 • 0 comments![]()
The new x-axis with bearing..
07/27/2016 at 14:45 • 0 commentsI'm currently building the new X-Axis train with additional bearing.. see below progress :)
Aluminium? No problem...
07/25/2016 at 14:29 • 0 comments![]()
Sunday Project update..
07/24/2016 at 10:59 • 0 comments -
The first object created :)
07/22/2016 at 16:09 • 0 commentsNot perfect yet - but also not bad for a not calibrated machine :)
It works!! First cutting test....
07/22/2016 at 15:35 • 0 comments -
The files are on github...
07/21/2016 at 06:23 • 0 commentsThe manual ( wiki ) starts to grow and the dxf/stl files are on github.
drawing ready to 95%
07/17/2016 at 23:41 • 0 commentsI just finished to redraw the hole machine with most details. Only the screws and nuts are missing. Not sure if i will add them all ;)
Thomas
