Function check
07/23/2016 at 02:08 • 0 commentsThe code for this was written in code composer studio, but as far as the encoder goes, it is the same.
Hookup
07/18/2016 at 13:11 • 0 commentsAMT312-D Pins Function EK-TM4C123GXL Pins Function Status 1 TX_ENC+ J1-3 (PB_0) RX(1) Not Yet Tested 2 RX_ENC+ J1-4 (PB_1) TX(1) Not Yet Tested 4 GND J2-20 (GND) GND Good 6 5 V J3-21 (VBUS) VBUS Good 8 B+ J4-32 (PD_7) B+ Good 10 A+ J4-33 (PD_6) A+ Good 12 Z+ J3-26 (PD_3) Index Good -
Code
07/18/2016 at 13:02 • 1 commentThe code taken from http://forum.43oh.com/topic/8875-problems-using-qei-with-ek-tm4c123gxl/ is good, and makes testing simple. The post was created because the person was actually using hall effect sensors for feedback, not an encoder.
#include <stdint.h> #include <stdbool.h> #include "inc/hw_gpio.h" #include "inc/hw_ints.h" #include "inc/hw_memmap.h" #include "inc/hw_types.h" #include "driverlib/gpio.h" #define PART_TM4C123GH6PM #include "driverlib/pin_map.h" #include "driverlib/qei.h" #include "driverlib/sysctl.h" void config_QEI() { SysCtlPeripheralEnable(SYSCTL_PERIPH_GPIOD); //Unlock GPIOD7 HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_KEY; HWREG(GPIO_PORTD_BASE + GPIO_O_CR) |= 0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_AFSEL) &= ~0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_DEN) |= 0x80; HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = 0; // Enable QEI Peripherals SysCtlPeripheralEnable(SYSCTL_PERIPH_QEI0); //Set Pins to be PHA0 and PHB0 GPIOPinConfigure(GPIO_PD6_PHA0); //GPIOPinConfigure(0x00031806); //0x00031806 =>GPIO_PD6_PHA0 GPIOPinConfigure(GPIO_PD7_PHB0); //GPIOPinConfigure(0x00031C06); // 0x00031C06 => GPIO_PD7_PHB0 //Set GPIO pins for QEI GPIOPinTypeQEI(GPIO_PORTD_BASE, (GPIO_PIN_6 | GPIO_PIN_7)); //HWREG(GPIO_PORTD_BASE + GPIO_O_LOCK) = GPIO_LOCK_M; // Configure quadrature encoder, use an arbitrary top limit of 2000 and enable QEI QEIConfigure(QEI0_BASE,(QEI_CONFIG_CAPTURE_A | QEI_CONFIG_NO_RESET | QEI_CONFIG_QUADRATURE | QEI_CONFIG_NO_SWAP), 2000); QEIEnable(QEI0_BASE); //Set position to a middle value QEIPositionSet(QEI0_BASE, 1000); //Configure and enable velocity QEIVelocityConfigure(QEI0_BASE, QEI_VELDIV_1, SysCtlClockGet()); // Divide by clock speed to get counts/sec QEIVelocityEnable(QEI0_BASE); } void setup() { config_QEI(); Serial.begin(9600); Serial.println("Start:"); Serial.println("--------"); } void loop() { uint32_t velocity, position; int32_t rotatingdirection; position = QEIPositionGet(QEI0_BASE); velocity = QEIVelocityGet(QEI0_BASE); rotatingdirection = QEIDirectionGet(QEI0_BASE); Serial.println(position); Serial.println(velocity); Serial.println(rotatingdirection); Serial.println("--------"); delay(1000); }Output:
jlbrian7
