Atomik Controller - Version 0.81 Alpha
08/24/2016 at 14:52 • 0 commentsA new image file for the Atomik Controller is available for download.
http://www.mediafire.com/download/a331sojk2w61v98/atomik_controller_0.81.img.7z
Atomik Controller 0.81
Fixed WPA/WPA2 WiFi Password Length.
Fixed Scheduled Tasks Page for Dual White Bulbs.
Other Minor Fixes and Updates.
Mi-Light Emulator does not work with Android devices. (Only iOS)Important Directories:
/var/working/atomik-controller - Contains the Git Repository. Many files linked from here.
/usr/atomik - Atomik API directory.
/usr/bin - Contains Atomik binaries ( transceiver, emulator, atomik-zone-update)
/var/atomik/scripts - Contains bash scripts for cronjobs and Atomik Controller administration./var/atomik/www - Contains the html for the Atomik Controller GUI.
Source Repositories Updated
08/19/2016 at 23:09 • 0 commentsThe Bitbucket and Github repositories have been updated.
A new DB Backup file has been added with the most up to date DB structure.A Crontab file for the root user has been added.
A Crontab file for the www-data user has been added.
MariaDB Username/Password ( root/raspberry )
Also, Phpmyadmin is installed on the Atomik Image. To access it go to http://192.168.1.100/phpmyadmin or to http://<IP Address>/phpmyadmin -
Atomik Controller Costs
08/18/2016 at 23:58 • 0 commentsTo purchase every part needed to build an Atomik Controller, for 4 RGB LED bulbs, 4 Dual White LED bulbs, and a hand held RF remote control it will only costs $240.00 USD. These prices are intentionally over estimated. Atomik Controller Kit Costs
Compatible Bulbs
08/18/2016 at 18:07 • 0 commentsCompatible Bulbs can be purchased at:
http://www.limitlessled.com/ - support@limitlessled.com – +64-7-544-4743 ( New Zealand )
http://www.futlight.com/ - milight20@futlight.com - +86(0755)-61176580 61176581 ( China )
http://easybulb.com/ - easybulb@gmail.com ( United Kingdom )
Tested with :
Limitlessled RGBW E26/E27 Warm White 9W, E26/E27 Edison Screw Dual White 9W, E26/E27 RGB+Warm White 6W
Futlight FUT016 9W RGB WW, FUT016 9W RGB CW, FUT014 5W RGB WW, FUT019 Dual White 9W, FUT017 Dual White 5W, FUT095 RGB Remote, FUT096 RGB Remote -
WiFi Password Length Limitation
08/15/2016 at 17:18 • 0 commentsThe WiFi password for WPA/WPA2 passwords can be no more than 16 characters in length
This has been upped to 32 characters in the current release.
V 0.81 - Will be uploaded in the next few days.
Error Found - Android Smartphone App
08/11/2016 at 03:09 • 0 commentsThe Android Smart Phone app crashes when talking to the Atomik Mi-Light emulator. No fix has been found yet.
The iOS Smart Phone app works still.
Further testing with other Android devices will be done to confirm this error exists on all Android devices. -
New RF Remote Test
08/04/2016 at 18:38 • 0 commentsI have tested a few different Mi-Light Brand remotes. Both are RGB but they are different revisions.
Both seem to be easily detected by the Atomik Controller and applied to a light zone.
Updated Task Details Page
08/02/2016 at 19:55 • 0 commentsFixed and error on the task_details.php page.
Issue: Brightness settings did not appear for White Only bulbs when Scheduling a Task.
Resolved!
Rahim Khoja
