I'm pretty much learning how to use the PCB software. so far I've noticed that with it, you can't create traces that look as artistic or somewhat abstract as I want them too look. so I guess I'll end up finishing the PCB with KRITA which is an open source Image editing program similar to Ps. why? well, at this point I'm simply going to make a file for manual PBC etching that I can print in transfer paper, rather then an actual .pcb file I can send to some manufacturer. In the future I will totally want to create a more professional version that can by printed by someone else in bigger quantities.
Portable Network Graphics (PNG) -
162.09 kB -
07/19/2016 at 02:28
