The Hacked calculator as LCD:The sound generator in Action:
When it is worth doing, it is worth overdoing. Based on an idea from Instructables.com, but better, shinier and with more features.
cheapoPocketCalcDisplayLive.hThe Arduino-Library to use a pocket-calculator as LCD. Header-file.x-chdr - 1.65 kB - 07/19/2016 at 19:00 |
cheapoPocketCalcDisplayLive.cppThe Arduino-Library to use a pocket-calculator as LCD. Main .cpp.x-c++src - 6.08 kB - 07/19/2016 at 18:59 |
sound_generator_440Hz.inoA kastrated test-version of the sound_generator file that will play a 440 Hz sine-wave on an arduino without pots connected. For testing the R-ladder-DACx-arduino - 73.91 kB - 07/19/2016 at 18:58 |
sound_generator.inoThe current sound-generator firmware as described and shown in the videox-arduino - 78.95 kB - 07/19/2016 at 18:58 |
the calculator hack is definetly brilliant and is easily obtainable..." kudos for that sir"
so brilliant in fact i signed up just so i could say so.
Greetings, you could send me the program for this project?
Hi, do you have a version of code using a 2 x 16 LCD display?
