I tried to get some data out of a KKMOON branded laser range meter.
It's inside is from SNDWAY and looks basicly like the UNI-T UT390B+. Moreover there were some debug pads inside wired to RX and TX but they were dead.
First I did some measurements on different pins, like Simon did, but finally I gave up since it was too time consuming.
Now I have orded some other device beeing supposed to have an active RS232 port. So I will keep you informed if I have any news.
Moreover I attached the information I could find out about the pinning - it's written in German. Unfortunately I couldn't upload the pdf file.
Reading the distance from the above shown laser distance meter works now with an Arduino Mini.
Excellent work! Thanks. Would you mind me adding the link to the project description/details? Or would you prefer if we wait for the "more to come" that your blog promises?
Go ahead, add it. I will keep the blog post up to date with my work.
I'm trying to hack the above mentioned meter. See https://www.mictronics.de/2018/02/laser-distance-meter-hack/
Found what look like an SPI bus on a missing chip footprint. Any help appreciated.
Sorry, didn't get an alert for this comment. Replied above though.
Stefan, I've only just seen your post - wow! Thanks for sharing. It's disappointing that these are less easy to hack than we'd hoped but I'm sure that people will find a way and it will all become a lot faster if we build off each other's discoveries. It's demoralising when we hit hurdles and walls but keep up the good work!
