The design consists of two servos, mounted in a way in witch one servo pans the other on an x axes, while the other servo tilts a laser on it's y axes. The laser is turned on and off with a transistor, and a camera shutter control is operated by a transistor. This is all controlled by an arduino one control board. A camera with a very slow shutter speed (usually 10-13 seconds) captures all movement of the laser, and creates "digital" light paintings.
A python based GUI sends strings of characters to the arduno via serial connection. The arduino stores the position of the pan, and the tilt servo in two global variables, creating a sort of "pseudo-vector" as an index for the position of the laser. Commands are sent within {brackets}, and text to be "painted" outside of the brackets. The arduino has a function for each letter, and command, that manipulates the position of the servos, and the status of the transistors controlling the laser, and the camera shutter control.
lwapd
Adam Oakley
robives
