Since the code is portable to several platforms under the arduino IDE, you should be able to use an esp8266-12 and add wifi capabilities to this. Either show a log of when the litz was trigger or using an outbound wifi connetion SMS page/email when a litz signal is recevied. I dont have time to explore this option as this time but may do so in the near future.. If you give it a try let me know.
