When I acquired the WICE-4M it only had the 16 bit EPROM plugs.
I need the two 8 bit EPROM plugs so I started to make my own.
Vero Board from local electronic store.
Measure up what I need.Cut them out genitally, I used knife and pliers.
Separate the into two, and with very sharp knife cut away the copper approximately down the centre, getting it ready to solder in the IDC 34 Headers.
Soldered IDC headers.
Long pin SIL sockets very handy, cut to size and soldered in, added SIL machined pin on the end for stability.
The end product, all I need to do now is to test it.
