The complete tutorial for this project is inside the website www.HomeAutomationServer.com.
After you login you'll be able to setup everything in no time!
You can use this platform with Arduino and ESP8266:
Home Automation Server is a provide a free platform that allow you to control your home from anywhere in the world.
Recently I've integrated Home Automation Server with the ESP8266.
Here's the new login page for the ESP8266: http://app.homeautomationserver.com/
How to use Home Automation Server with ESP8266? Read this tutorial here
New Tutorial for HomeAutomationServer.com "How to control 220V Lamps from anywhere in the world".
Read this blog post: http://randomnerdtutorials.com/arduino-control-220v-lamps-from-anywhere-in-the-world/
All the Instructions can be found after you create and login in your account!
The main problem of all the home automation projects is ... You have to login to someone else's server to create an account to use it. I would like to see someone create a Home automation solution that uses an Arduino Uno or MEGA, WITHOUT using someone else's server. Maybe using an ESP8266-12 or a NRF24L01 group of boards. I refuse to log into someone else's server to transmit / receive my data.
was very inspired by this project.
I belive that smart home based on Arduino is really a great tool.
