Updated photos with progress on the new deck. Will be adding more information soon as I comb through a lot of additional progress pictures from the new build. Stay tuned!
Zip around on your own custom deck at lightning speeds. Never miss class again.
Catching the bus to get across campus can be a hassle, and a bike's not a plausible solution for me, so I decided to give a longboard some extra power to kick me around. This board has a theoretical top speed of around 20mph and approximately 10 mile range. All built with easy-to-find hobby electronics.
First, you're going to need a deck. If you're working on a budget, go to Walmart or Academy Sporting Goods or similar and pick up something cheap for around $20. The above deck is a bustin mini maestro, which I think I got for $80-90. The primary difference is quality of the build / size; this is a longboard deck (though a small one) and it gives me more room to work with. You can get away with using a cheapo $20 skateboard, though.
Next get some trucks. These are inexpensive Paris trucks off Amazon.
If you get a cheapo-skateboard, they'll come with wimpy plastic wheels. You need big, beefy ones if you're going to do some cruising. I recommend 70mm or so sized wheels, also off Amazon. They often come with bearings as featured above, but check out any online skateboarding / longboard resources if you're confused how to put all this stuff together.
The heart of this (and most EV projects) build is the brushless outrunner motor. Hobbyking is probably still your best bet for finding these. You'll want something with a relatively low kv rating (low kv = more torque). I went for the lowest they had available, a 149kv motor. I actually don't recommend it—get something in the ~300 range—because this will easily yank the board out from under your feet.
You're also going to need an ESC to run the brushless motor; I got mine from Hobbywing (no, that's not a typo. Hobbywing != Hobbyking). Don't worry, I'll go over how you figure out the correct values, etc. in a later post.
I really dig these Turnigy "Long" LiPo batteries. They may be a bit too long to fit between the wheels on a cheapo $20 deck, but there's plenty of space on any longboard, and it allows for great ground clearance.
The rest of the components you probably have lying around: you'll need an Arduino or similar microcontroller and some kind of remote control option. A Wii Nunchuck works great for this, and XenonJohn's tutorial is probably the best explanation for how to get started with it.
Assembly details coming up!
Send me a copy of your code, what programming language are you using?
I'll see what I can do.
Radical! Oh man ive been thinking about doing this for so long! Awesome to put it online dude!
Jorj Bauer
Jrsphoto
Hi guys,
I'm a total noob with this, but me and my friends started a project something like this. But we're stuck with the programming part. The Arduino reacts to the (wired) nunchuck but it seems like that the motor isn't reacting at all. I've looked kinda all over the internet and I'm kinda desperate so could somebody give me assistance please? Thanks in advance
