Now with an uplink to the mothership
12/07/2016 at 23:29 • 0 commentsI added a description how I made whitestar automatically connect to the mothership and upload the capture files. No running around with the HDD anymore!
Powersupply Mk. I
09/24/2016 at 19:47 • 0 commentsI started to build the power supply. Currently it has only the supercaps for keeping the kektop from rebooting ad the engine is started and I will test it for a while and see how it performs. Details in description :)
The batteries have arrived
09/03/2016 at 22:20 • 0 commentsThe battery pack has arrived.
It has the required volts & amps to run the whitestar, now I just need to integrate in into the system properly.
Documented automatic whitestar -> workstation -> wigle.net data handling
09/03/2016 at 22:07 • 0 commentsAdded a description of the automatic data handling process. Currently based on just moving the HDD around but does the job and automating it proved to be a fun task ;).
Enki
