Been a while since I posted an update.
The software has had numerous fixes including better compatibility for Firefox and Chrome browsers.
If you are interested in seeing a fully functional online demo system running where you can interact with preconfigured screens and also create / edit your own screens, please post a comment as I'm considering deploying the server into the Cloud if there is enough interest.
Well effective article for me! This is amazing and definitive guidelines and hugely valuable.
3d puff embroidery digitizing: http://www.digitemb.com/puff-digitizing
I didn't get time to setup a demo as I'm spending the time on porting the server software to .NET core (to make it fully open source and Linux compatible) as well as many improvements and updates. I will do a demo of the new software when it is ready (ETA 2 months - I do this in my spare time). The screenshots in this blog should give you a good idea though.
How easy is it to add plugins to this? For instance I have lots of Insteon and Z-Wave devices.
The hard work is done by the server software.
Its pretty easy - all the plugin has to do is manage the network connection to the device and any device semantics for control / monitoring. There is an API to receive a message into the plugin to send to the device, and another API to send a message from the plugin to the server software.
I can write a simple plugin in a couple of minutes but I'm obviously familiar with the software and C#, VB or Node.JS javascript which are the languages you can use for plugins. The process of writing a plugin is documented here in the project notes - if you get stuck I can help.
Also I am re-writing the server software in C# .NET Core (for Linux support native) timeseries message log, more powerful publish subscribe but the current version is quite functional and reliable to use.
That is good news! I currently use Homeseer 3 at my homes for automation. But it sure would be nice to have a fully functional open source HA solution, that also is not overly complex to use (OpenHAB), or ugly!
Looks very promising! I would love to check out a demo...
