So it seems like there are a few thermal imagers out there that made it through, so for the sake of completeness (and to eliminate the competition :D) I finished up my thermal imaging code...Here's a short video showing thermal/night vision:
To produce the final image, temperature readings are normalized, then converted to a rainbow (using a lookup table) and then scaled up (using bilinear interpolation) and finally, the thermal image is alpha blended into an RGB image and sent to the LCD...The result looks something like this:
http://hackaday.io/project/3000-Flir-Lepton-Thermal-Camera-Breakout
https://static.hackaday.io/images/9285341405903047687.JPG
So the IR sensor needs to be shifted a few mils, this might be enough to align them.
Now on a more serious tone, I'm following your project and really like your OpenMV concept and implementation. Good job! :)
